How to Save and Use Custom Themes in ActivePresenter 10
Have you ever wished you could save all the settings in the themes you’ve made to reuse later? If so, you come to the right place. Let’s learn how to save a project as a custom theme and use it in ActivePresenter 10.
Besides the built-in themes that ActivePresenter 10 offers, you can create your own themes with unique settings in this all-in-one authoring tool. Moreover, the app allows you to save them as custom themes to reuse whenever you want. Sounds interesting? Keep reading to find out detailed helpful information.
You will walk through 4 stages in this tutorial:
Make sure to download and install ActivePresenter 10 on your computer!
Save Custom Themes
The very first step is to save your project as a custom theme. Perform either of the following:
  • Access the Design tab > select Save Current Theme… from the bottom of the theme gallery. Then, type a name for your theme and click Save.
  • Click the File button > Save or Save As… Alternatively, press CTRL+S on the keyboard. Next, select ActivePresenter Theme (*.aptheme) in the Save as type list > click Save.
Save a theme as a custom theme
Normally, your file is saved in the ActivePresenter Templates folder (C:\Users\<user_name>\Documents\ActivePresenter Templates (for Windows) or /Users/<user_name>/Documents/ActivePresenter Templates (for macOS)).
Custom theme example
Note: All the themes appear according to the alphabetical order of their names.
Use Custom Themes
Overall, ActivePresenter 10 lets you create projects from custom themes on the Start Page. To create a new project based on “Nature”, do as follows:
Step 1: In the Start Page > right-click or click the Nature thumbnail. Next, the Preview dialog appears like this:
Use Custom Theme
Here, you can:
  • Create a new project. ActivePresenter 10 offers you six options: Blank Project, Blank Responsive Project, Project from Template, Responsive Project from Template, Record Screen as Video, Record Interactive Simulation.
  • Edit or Delete the theme.
  • See slides in the selected custom theme. To do that, click Previous or Next.
  • See other custom themes. To do that, click Previous Item or Next Item.
Step 2: Click one of the six options above to create a new project. For example, in case you select Blank Project, this is what you get:
Create blank project from the saved
custom theme
Customize Custom Themes
Basically, custom themes are also themes. Therefore, you can edit and work with them the same way as you normally do.
Customize the saved custom theme
Firstly, access the Design tab, as you can see your custom theme is displayed with a gray outline in the theme gallery. From here, you can:
  • Modify Theme Colors.
  • Change Theme Fonts.
  • Change the Preset Background Style.
  • Add or customize items on Slide Master.
  • Save as Slide Templates.
Share Custom Themes
Let’s say that you want to share your custom themes with your friends and co-workers. For this reason, ActivePresenter 10 will surely take you one minute. All you need to do is send the .aptheme files to them. Then, make sure those files are saved in the ActivePresenter Templates folder on their computer. These themes will show up in the Custom section of the app’s Start Page.
That’s it! Hope that it inspires you when working with the app. Stay tuned for upcoming tutorials on our page. Don’t forget to visit our YouTube channel for more engaging video tutorials.
More articles:
Get Started with ActivePresenter 10
Work with themes
Work with theme colors
Use Slide Masters
Work with theme fonts
