How to Generate AI Images in ActivePresenter 10
Creating stunning visuals for your eLearning courses has never been easier. With ActivePresenter 10 – an AI-powered eLearning Tool for eLearning, you can now generate AI images directly inside the app, saving time and boosting creativity. No need to search for stock photos or hire a designer, AI-powered image generation gives you unique, high-quality visuals in seconds. In this article, we’ll walk you through the steps to generate AI images.
How to Generate AI Images in ActivePresenterThis content is provided by YouTube. Loading it may set cookies and send data to YouTube. Google
💡 Make sure that you own an ActivePresenter license to unlock AI features.
AI Image and AI Credits
ActivePresenter relies on AI services to provide features like Image Generation. Each time you generate an image, the system consumes AI credits. To understand how credits are calculated, check out the article: How AI Credits Work.
You can also keep track of your usage at any time. Just open the AI tab to view your credit statistics and remaining balance.
AI credits
Steps to Generate AI Images in ActivePresenter 10
After launching ActivePresenter and opening your project, follow these simple steps to start creating your own AI-powered images:
Step 1: Access the AI tab > click Image Generation. This opens the Image Generation dialog.
Step 2: Adjust the Settings in the dialog.
  • Provider: Use the AI Image provider that ActivePresenter provides you. Or Add Custom Image Generators by clicking the plus button Add. You can also edit Edit or remove Remove the custom image generators.
  • Style: Select an image style from the available list.
  • Model: Select an AI image model with the corresponding credits.
  • Aspect Ratio: Choose a suitable ratio for your image.
Step 3: Enter a prompt in the blank > click the Generate button to start generating your AI image.
Here is the AI image generated in ActivePresenter 10:
AI image generated by ActivePresenter 10
Note: The more detailed your prompt, the better the result.
Step 4 (Optionally): You can perform the other actions in the Image Generation dialog:
  • To enhance a prompt with AI, click Enhance Prompt.
  • To save a prompt and reuse it later, click Save Current Prompt. The Save Prompt dialog appears, allowing you to enter a name for your prompt > OK.
  • To edit a saved prompt, click the Edit Saved Prompt.
  • To delete a saved prompt, click the Remove Saved Prompt.
That’s it! Visit our YouTube channel for more interesting videos updated.
Download ActivePresenter today and experience that app!
📌Quick Q&A about Image Generation in ActivePresenter 10
Can I generate AI images directly inside ActivePresenter 10?
Yes. ActivePresenter 10 includes an AI Image feature that lets you create unique visuals right within the app.
Do I need an internet connection to use AI Image generation?
Yes. Since the AI engine runs in the cloud, you need an active Internet connection to generate AI images in ActivePresenter 10.
What image styles are available with AI Image?
You can choose from Photography, Anime, Claymation, Origami, and more.
Is there a limit on how many AI images I can generate?
No. You can use all the AI credits in your Standard or Pro licenses to generate AI images. You can also buy additional credits.
Can I use AI-generated images for commercial projects?
Yes, provided your usage complies with the terms of service.
Can I edit the AI images after generating them?
Yes. You can resize, crop, and enhance them in ActivePresenter.
Related articles:
