Top 5 Websites to Download Free Sound Effects
Are you looking for a website to download sound effects for free? This blog will present well-known sites to download free sound effects of all kinds, so you can find ones that fit your needs.
Finding a site where you can download all the free sound effects you need can be challenging. That’s because a site may have sound effects in one category but not in others. Therefore, you may need more than one site on your list to cover all the categories. With that understanding, this blog will present well-known sites to download free sound effects of all kinds, so you can find ones that fit your needs.
Download free sound effects
1. Zapsplat
2. Mixkit
3. Quick sounds
4. Pixabay
5. Free Sound Effects
When it comes to downloading free sound effects, we cannot help mentioning copyright. Each website has its license agreement. For example, you can download a sound effect file for free. But, it depends on the website policy whether attribution is required or not. For more information, you can refer to this blog: 10 Fantastic free background music sites for video editing.
1. Zapsplat
free sound effects
To date, with an enormous number of over 100.000 sounds, Zapsplat deserves to be the first name appearing on the list of top 5 websites to download free sound effects. You can use the sounds for film-making, games, YouTube videos, or any project.
A straightforward interface lets you find the Free sound effects to download instantly section right at the top of the website. After that, you can access all the sound effects divided into specific categories by clicking the Show me the sounds button. Also, you can type your keyword in the Search field.
For example, here is what you see when you search for correct answer sound effects:
zapsplat
Two available sound files for download are .mp3 and .wav. You can download the free sound effects as a .mp3 file. If you want to download the .wav files, you need to register as a Gold member.
2. Mixkit
free sound effects
Mixkit is the second name on the top 5 websites to download free sound effects.
As you can see, its interface is so friendly. Sound effects are divided into 11 big categories listed at the top of the website. You can find the sound you want in each category or search it in the Search Sound Effects box. The downloaded file formats are .mp3 and .wav.
All sound effects are royalty-free and can be used without attribution, plus no sign-up is required. The free sound effects license of Mixkit means you can use these sounds in both commercial and personal projects.
If the Mixkit doesn’t have the free sound effects you want, it will recommend royalty-free sound effects from envatoelements.
3. Quick Sounds
quick sounds
Like other free sound effects websites, Quick Sounds has an easy-to-use user interface. You can easily search for the sound effects you want in the Search box at the top of the site or in 16 sections specified into different categories below it.
The loading speed is fast, so you can easily listen to the preview before downloading files. The downloaded file format is .mp3.
Besides, the site allows you to download free sound effects without signing up or signing in. After that, you can use those sound effects in both commercial and personal projects. However, you need to add credits or link back to the website. Don’t credit them from any social media platform. For instance, you add credits to the project itself, such as a YouTube video description, app, or game credits page.
4. Pixabay
pixabay
Not only famous for stunning free and high-quality images, but Pixabay is also a place where you can download fantastic free sound effects.
Simply select Sound Effects and enter your keywords in the Search field without logging in. Then, all the related sound effects will show up. After that, you can classify them by their durations or 8 different categories. The downloaded file format is .mp3.
Pixabay does not require you to add credits, but you can credit and link back to the website as a way of saying thanks.
Free sound effects
Free Sound Effects is the last name on the top 5 websites to download free sound effects without registration.
Access the Free Sound Effects section in the left-hand menu. There are over 10.000 free sound effects available for you to download. However, there are some limitations to using free sound effects. You can only use these sounds for personal or educational purposes. When you need to use them for another purpose, for example, a commercial one, you have to search for royalty-free sound effects under the Paid Sound Effects section.
Conclusion
So, above are the top 5 websites to download free sound effects without registration. Once you find the sound you like, you may need to add it to your project to edit. Let ActivePresenter, a free screen recorder and video editor help you with that. Not only a professional eLearning authoring tool, but ActivePresenter is also incredible video editing software. The app allows you to add video, sound, or image files and edit further with powerful commands. You need to add those files to the app and then perform the editing steps.
Click the button below to download ActivePresenter and give it a try now!
