(Last Updated: February 23, 2018)
Cursor path enables you to simulate mouse movements and clicks, which is extremely useful for software training. Today’s article will show you how to add cursor paths to your project.
When you record screen, ActivePresenter records your mouse movements and converts them into cursor paths. You can change the mouse cursor and add mouse click effects after that.
Besides, ActivePresenter allows you do manually insert your own cursor paths and style the path the way you want. In general, the idea is insert a cursor path, then add points to the path and place them over buttons or other clickable objects. Optionally, you can add click points, where ActivePresenter produces the click sound in the rendered project.
Adding Cursor Paths
Here’s how:
Step 1: Select the slide you want to insert a cursor path. Remember that only one cursor path can be added to each slide.
Step 2: Go to the Annotations tab > Cursor Path.
cursor paths 01
The cursor path will appear in your slide. Each cursor path has a start point (1), an end point (2), and a dotted line (3) presenting the movement of the pointer between these two points.
cursor paths 02
  • The red arrow shows the direction of the cursor movement.
  • Half of the dotted line toward the start point is green in color, and its remaining half gradually turns red toward the end point.
  • The spacing between dots indicates the speed of the cursor on screen. That is, the faster the cursor moves across the screen, the farther are the dots. On the contrary, closely spaced dots mean slower speeds.
  • When you click the start point, a square appears to denote that the start point is currently selected. ActivePresenter shows a control point (4) associated with the end point. The line between the control point and the end point is tangent to the path at the end point. Move the control point to change the shape of the path.
Step 3: Add points to the path. Hover anywhere over the dotted line, the pointer changes to a pencil. Click to add a point and drag that point to the position you want.
cursor paths 03
  • Highlight the mouse cursor to locate it on the screen. To do that, select one point on the path and go to the Properties pane > Size & Properties > Cursor Path.
  • Select Show to end to show the path until the end of the slide.
cursor paths 04
Changing the Path of Mouse Movements
When you insert a cursor path object, the whole object is selected so that you can move it to another position in the slide. If you want to change the position of the start or end point of the path, first click anywhere on the Canvas to deselect the path. After that, click the start point or end point and drag it.
Any given path segment can be made a curve or a straight line. Just select the start point and from the context menu, select Straight Cursor Path or Curved Cursor Path.
cursor paths 05
Tip: Another way to change the path is move the control point. This point appears when you select the start point of the path.
Changing Cursor Style
To add or change the cursor style, select a point and do the following:
Step 1: Go to the Properties pane > Cursor > Cursor Image.
cursor paths 06
Step 2: Choose the cursor image you want from the gallery. You can even use your own cursor image by clicking the From File button and select any image file on your computer.
cursor paths 07
Changing the Timing and Speed of Mouse Movements
Take a look at the cursor movement in time. The cursor path has three segments in total.
cursor paths 08
  • Each gray vertical line (5, 8) denotes the end time of a segment and the start time of the subsequent segment.
  • The instant when the cursor starts moving is marked with a red vertical line (6).
  • During the 5→6 gap, the cursor is at rest. This is the Start Duration of the cursor.
  • The instant when the cursor stops moving is marked with a second red vertical line (7).
  • During the 7→8 gap, the cursor is at rest. This is the Stop Duration of the cursor.
  • The green horizontal line (9) indicates the Moving Duration of the cursor.
  • The yellow diamond (10) represents a click point. This is where ActivePresenter simulates a click by creating a click sound and click effect.
Drag the lines above to adjust when the movements of the cursor begin and how long they last. Alternatively, go to the Properties pane > Cursor > Timing to adjust the timing and speed of the mouse movement.
cursor paths 09
Adding Click Points and Click Effects
You can convert any point along the cursor path into a click point. Select a point and perform the following:
Step 1: Go to the Properties pane > Cursor > Click Point.
cursor paths 10
Step 2: Select a desired type of click point from the Type drop-down list. Then, further customize the click point with other options including Click Sound, Click Time, and Click Effect.
Step 3: Click Apply To All to apply changes to all click points of the same type.
Continuation of Cursor Paths between Slides
Normally, when you drag the start or end points of a cursor path, ActivePresenter also moves the corresponding point in the previous/next slide to ensure a smooth mouse movement. That’s thanks to the Cursor Snapping tool in the View tab.
If you don’t want the cursor path to move continuously between slides, go to the View tab and turn off Cursor Snapping.
cursor paths 11
In rare cases, the cursor path can be out of sync, making an abrupt movement of the mouse cursor when transitioning between slides. To avoid this, stitch the ends of the cursor paths of adjoining slides together.
  • Right-click the start point, click Snap to Previous.
  • Right-click the end point, click Snap to Next.
cursor paths 12
Tips to Compose Cursor Paths
Here are a few tips for composing a realistic-looking cursor path:
  • Avoid showing the mouse all the time. It is OK if the mouse vanishes from the scene for a while.
  • Remove aimless wandering of the mouse to prevent distraction.
  • Don’t use the mouse as a presentation pointer. Instead, use shapes, zoom-n-pan, spotlight effect, or other types of annotations.
  • The resting periods are important in realistic depiction of the mouse movement. In fact, they contain the click points (you cannot click while the mouse is moving).
  • When you are narrating something, keep the mouse at rest.
That’s all about cursor paths in ActivePresenter. Try it today and feel free to contact us if you need any support.
Pin It on Pinterest
