How to Create a Spotlight Effect in ActivePresenter 8
by | Mar 18, 2020
(Last Updated On: May 14, 2020)
Spotlight is a useful annotation object in ActivePresenter. It helps you easily direct your audience’s attention to a specific part of a slide. So, in this tutorial, you’ll learn how to create a spotlight effect in ActivePresenter 8.
How to Insert
To create a spotlight effect, in the Insert tab, click Spotlight.
Insert a spotlight
A spotlight object will then be inserted into a slide. It retains the original brightness of a particular area while darkens the rest of the screen.
Spotlight in ActivePresenter 8
How to Customize
Changing Position and Size
Reposition and resize the spotlight object as you wish. You can drag the object to a new position and drag the resizing handles (green dots) to change the spotlight size.
Alternatively, in the Properties pane, change the values in the Transform section. This way provides more precise positions of the spotlight effect on the slide.
Position and size of a spotlight effect
Modifying Start Time and Duration
The spotlight effect will start at the starting point of the object (1) and end at the endpoint (2). The object Time Bar indicates the effect timing.
Spotlight time bar
To change the start time of the spotlight effect, do either of the following:
  • Click the spotlight effect object Time Bar in the timeline pane, then the mouse turns to a four-way arrow, drag it to the left or right. Besides, you can drag the starting point (1) to change the effect start time. However, using this way will change the effect duration at the same time.
  • In the Timing section of the Properties pane, enter a value in the Start Time spin box (3).
Time and duration
To adjust the length of a spotlight effect, do one of the two following ways:
  • Drag the endpoint (2) to the left or right to decrease or increase the duration, respectively.
  • In the Timing section of the Properties pane, enter a value in the Duration spin box (4).
Changing Shape
You can change the spotlight shape as you want. In the Format tab, you first need to click Change Shape, then choose a new shape.
Change shape
Adjusting Opacity
Moreover, you can adjust the transparency level of the area surrounding the spotlight shape. Just select the spotlight object, then click the Properties pane > Style & Effects > Fill > Opacity.
Change opacity
Besides, it’s your choice to use Gradient Fill to make more effects for your spotlights.
Tips: When adding another spotlight right after the first one ends, you should add entrance and exit effects to those objects to make a smooth transition between them. Also, the entrance effect of the second spotlight should appear exactly at the time when the exit effect of the previous one starts.
Note: You cannot highlight several parts of your screen at the same time, which means you cannot add multiple simultaneous spotlights.
That’s all about spotlight effects in ActivePresenter. Take advantage of this effect to attract your audiences’ attention. Feel free to contact us if you have any questions.
Insert and Style Shapes
Insert an Image
Animate Objects
Insert Text Captions
Insert Equations
Use Zoom-n-Pan
Add Close Caption
Add Animation Effects for Text
