(Last Updated: October 18, 2018)
ActivePresenter as a built-in facility to take screenshots. It is not a key feature of this ultimate tool, but you’re still surprised, for sure.
Taking screenshots with ActivePresenter is a lot easy. You can take screenshots of a window, an object, the full screen (also your desktop), and an application or a region of your screen. You’re allowed to:
  • Edit screenshots after capturing by adding shapes, text, cropping, blurring, etc.
  • Paste screenshots taken by other methods on the Canvas and edit as normal. You can paste screenshots captured by pressing the PRINT SCREEN key or by other tools such as the Snipping tool.
To take screenshots, click the Annotations tab > Screenshot. Then, select one of the four modes to capture what you want. Note that before capturing, you can adjust some screenshot settings by clicking Screenshot > Options. Details about these settings are available at the end of this tutorial.
take screenshots 01
Capturing a Window
To capture a screenshot of the target window or any object in it, do the following:
Step 1: Select the Window mode take screenshots 02.
Step 2: Use the mouse to select a window or its object such as toolbars, panes, or menus. Mind that:
  • You can use the mouse as normal because clicking does not trigger a screenshot.
  • A red dashed outline is shown around areas that can be captured.
take screenshots 03
Step 3: Press PRINT SCREEN or CTRL+Click to take a screenshot. The screenshot will be placed in the current slide in ActivePresenter.
Capturing an Object
To capture a screenshot of any object in any window, perform the steps:
Step 1: Select the Object mode take screenshots 04.
Step 2: Use the mouse to select the object you want. Mind that:
take screenshots 05
Capturing the Full Screen
Select the Full Screen mode take screenshots 06 to capture a screenshot of the entire screen of your PC. Right after that, ActivePresenter minimizes its own window and captures whatever visible on your computer screen.
So, be careful to prepare your screen before selecting this mode.
Capturing an Application or a Region
ActivePresenter lets you capture a screenshot of the top-level window of the target application, or a rectangle region of the screen. Take the following steps:
Step 1: Select the Application or Region mode take screenshots 07. Immediately, a blue rectangle and the Take Screenshot dialog appear.
take screenshots 08
Step 2: Use the blue rectangle and the dialog to specify what and how to capture. You can drag and position the rectangle around the target part of the screen. You can also resize it as you want.
The Take Screenshot dialog works as follows:
  • Screenshot Usage: Insert the screenshot as an image to the current slide, and/or as a background image of the new slide that will be inserted below the current slide.
  • Screenshot Size: Specify the size of the screenshot. The Preset Sizes button allows you to select from several predefined sizes.
  • Application: Provide a list of all current applications running on the PC that have a visible window.
    • Fit To Application: Resize the blue rectangle to fit into the application window.
    • Fit To Boundary: Resize the application window to fit into the blue rectangle.
  • Wait for: Specify a delay (in seconds). Use this delay to quickly interact with the target application and capture its response.
Step 3: Click Take Screenshot to capture a screenshot.
Note: This screenshot mode shares some options with two recording modes of ActivePresenter. See Recording Video Demos and  Recording Software Simulations for more details.
Saving Screenshots
Right after you take screenshot, ActivePresenter places the screenshot in the current slide. Export it for using and sharing.
To do that, right-click the image > Export To File…. Specify the file name, file format (PNG, JPG, or BMP), and file location, then click Save to export.
  • The exported screenshot doesn’t include annotations such as shapes, callouts, and text (because they are separate objects, you export the screenshot only).
  • If you wish to save an entire slide as image, click the Slide tab > Save Slide as Image. You can even export the entire project as images, click the Export tab > Images.
Screenshot Options
ActivePresenter provides four options to adjust screenshot settings before capturing. To access these options, click the Annotations tab > Screenshot > Options. Note that the first three options work only when capturing a window at any level.
take screenshots 09
  • Capture Window Shadow: Capture the drop-shadow around the border of an application window in non-maximized state.
  • Process Rounded Corners: Capture the rounded corners of an application window in non-maximized state.
  • Use Opaque Background: Replace the semi-transparent border of windows in the screenshot with an opaque border.
  • Show Usage Guide: Show a yellow text box that describes how to capture the screenshot when capturing windows or objects.
take screenshots 10
That’s it. So quick and easy to take screenshots with ActivePresenter. Download the app and take whatever screenshots you want.
